Mag wheels
Old Jun 14, 2017 | 01:44 AM
juicebox's Avatar
juicebox
Stage IV
Originally Posted by stewbeezer
'06 & '07 have 1" axles. '08 & up have a 25mm axle. You need to change the bearings. You can't use '06 or '07 bearings because they are wider. You can replace the bearings in the wheel with some 1"x52mmx15mm bearings available at a good bearing supplier. I changed my '07 Dyna Superglide rear wheel for a Fatbob wheel doing this swap.
Ah! Thanks!!! So this is for '08+ wheels, do you by any chance know the bearing size for older wheels then '06?
BiKenG
Oct 21, 2018 09:09 AM
sgillikin
Wheels/Tires
Mar 22, 2016 10:41 AM
Jackazz
Oct 1, 2012 11:55 AM
Tanker2
Mar 28, 2011 04:48 PM
rdrnr03
Jan 6, 2006 11:00 AM
