How many miles on your big bore?
Old Jul 1, 2017 | 08:42 AM
archergodwin's Avatar
archergodwin
Default How many miles on your big bore?
For those of you that have gone big bore kit route, .. 103, 106, 107, 110...with other than stock cams, how many miles you got on your ride, and what issues have you seen related to the change?
Thanks!
Old Jul 1, 2017 | 03:51 PM
Reindeer's Avatar
Reindeer
I had about 15k miles on my 103" SE cylinders when I pulled them off to go 117", which only had about 600 miles on it so far.
No issues with the 103" setup other than some pinging on heavy acceleration, but that was a tuning issue I never got resolved.
Old Jul 1, 2017 | 04:29 PM
F86's Avatar
F86
The original owner of my 2000 88 had the motor built when it was about two years old. 95" Wiseco pistons, First SE 211 cams, then Andrews TW60s, quite a bit of headwork, manual compression relief valves, etc. After about 15,000 miles and fifteen years it was pinging under acceleration (despite taking out some spark advance), leaking moderately from the upper and lower rocker boxes, and burning some oil (not terribly). I'm in the process of a full freshening now, but I probably could've just resealed the rockers and cleaned all of the oil/carbon deposits out of the heads and pistons and ridden it for quite a bit longer before the oil burning really got obnoxious...
Old Jul 1, 2017 | 05:09 PM
Ruralmed's Avatar
Ruralmed
Default 25k, hard loving miles
I have taken a few 2-5k trips. Mostly bar hops and trips to drag strip. Somehow original SE Clutch and 103 still holding together...
But, then again dealer promised 100k...lol
Old Jul 2, 2017 | 08:09 PM
Nickd2689's Avatar
Nickd2689
17 lrs with se 117 street kit. About 5000 miles so far but I just installed it in feb. only issue so far is it runs a lot hotter but it's nothing that can't be fixed. I love it.
Old Jul 2, 2017 | 09:44 PM
Wskybent's Avatar
Wskybent
About 5k on a fuel moto 107" kit with woods cams. Last fall I sheared all the splines of the interior of a Andrews 30t pulley and grenades my compensator. New pulley and SE comp now. No issues since.
Old Jul 3, 2017 | 08:44 AM
NorthWestern's Avatar
NorthWestern
SE 585 cams on the 110 since 100 miles. 5K with a canned tune, and 1K since the dyno tune. All I want is more power. Thinking about the FM 113 kit, with the 999 cams and 10.5 heads. I worry the bottom end can't take it, though
Old Jul 3, 2017 | 09:46 AM
Reindeer's Avatar
Reindeer
I was afraid that was going to happen to me, so I went straight to the 117", after a couple years as a cammed 103". Glad I did. I can't imagine wanting more power on a Dyna.
cike
May 18, 2022 05:54 AM
DBLX
Feb 5, 2016 05:24 AM
swampking
Nov 3, 2007 05:05 PM
swampking
Nov 2, 2007 06:00 AM
O5HOG
Exhaust System Topics
Nov 2, 2006 02:24 AM
