Anyone considering magnum shielding, read this
Old Jul 21, 2017 | 11:42 AM
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
Originally Posted by nickd2689
what did you install them on
2006 fxdbi
Old Jul 21, 2017 | 01:45 PM
jeffr0000's Avatar
jeffr0000
I went with 14 apes and a 1.5 riser, plenty of wire was left stuffed in the frame.
Old Jul 21, 2017 | 01:50 PM
Nickd2689's Avatar
Nickd2689
you ou did this on a lrs?
Old Jul 21, 2017 | 02:04 PM
jeffr0000's Avatar
jeffr0000
No, sorry that was on a 15 Wide Glide. OE it had a 6 inch riser and a drag-style bar.
Old Jul 21, 2017 | 02:12 PM
SixDD's Avatar
SixDD
Aye, it's been a while since I did it, but I remember pulling the wires out of the bottom of the frame just above the engine, connecting them, then tucking them back into the frame and replacing the plastic frame cap that covers the hole. Plenty of wire when converting from the OEM mini apes to 14" narrow apes.
Old Jul 21, 2017 | 03:55 PM
Nickd2689's Avatar
Nickd2689
ok thats definitely comforting because I believe the wide glide is the same setup as the lrs. Correct me if I'm wrong though. Thank you
Old Jul 21, 2017 | 07:20 PM
Rhobz's Avatar
Rhobz
1st Gear
My brother and I will be installing 12" Lucky Dave's San Diego Bars with +6 brake and clutch from Magnum Shielding on Sunday on my FXDLS.
Big thanks to the OP because I will be opening the box from Magnum Shielding tonight and would probably be pretty upset seeing the jigsaw ABS block at first.
Bdc0923
Feb 22, 2019 04:35 PM
R.Canales
Oct 24, 2016 10:16 PM
hutch08
May 6, 2012 11:15 PM
DocHarley
Nov 1, 2010 12:15 AM
