Bike won't start in gear
Old Jul 27, 2017 | 04:28 PM
florida_italian's Avatar
florida_italian
Default Bike won't start in gear
Is this normal? Most times my bike will not start unless it is in neutral.
In first gear with the clutch pulled I get nothing. My sportster started in gear no problem.
Old Jul 27, 2017 | 04:33 PM
Smogbob's Avatar
Smogbob
Is it on the kickstand when you do this.
Old Jul 27, 2017 | 04:40 PM
NORTY FLATZ's Avatar
NORTY FLATZ
USA market bike?
Old Jul 27, 2017 | 04:42 PM
tnriverluver's Avatar
tnriverluver
Do you by chance have a tune from Power Vision??? Mine did that with one of the tunes I loaded.
Old Jul 27, 2017 | 04:57 PM
florida_italian
Don't know how to put multiple quote in one reply so...
NO- kickstand up and no start.
Yes USA bike from south Florida.
And it came with a Screamin Eagle tune, AC, and Rineharts
Old Jul 27, 2017 | 05:30 PM
Smogbob's Avatar
Smogbob
Inside the clutch handle assembly there is a button that when depressed by the clutch handle should allow the engine to start IN GEAR. Right?
But for all this to work both the clutch handle assembly and switch housing have to be fitted against each other tightly or the clutch lever cam won't depress the button far enough to work.
Old Jul 27, 2017 | 05:32 PM
florida_italian
Wow never knew that was there. Thanks I will check it.
Old Jul 27, 2017 | 05:49 PM
WH1_T-type's Avatar
WH1_T-type
Have you recently changed your risers or bars? My FXDLS started doing this right after I changed the risers and pretty sure I needed to get in an adjust the clutch a tad. Deployed right after though so now it sits and waits until I get back.
Also rented a '17 Road Glide in Hawaii when we stopped and it was doing it as well. I know it was because the housing was loose as it was REALLY loose. like I had to keep stopping and tightening it up. Pretty frustrating.
Old Jul 27, 2017 | 06:20 PM
checkers's Avatar
checkers
My 2011 FL will crank/start in gear with clutch lever pulled in. My 2011 Heritage would not, it had to be in neutral. It's a bitch on the Heritage when I stalled it on the RR tracks and a train was coming.
Old Jul 27, 2017 | 06:32 PM
fxdx1985's Avatar
fxdx1985
Why do you want to start it in gear? You'd have to be holding the clutch in anyway or it would pop forward and die immediately, unless you were sitting on it. At that point, might as well be in neutral anyway and just shift into 1st and take off....
