Terrible handling
Old Jul 28, 2017 | 04:44 PM
Smogbob's Avatar
Smogbob
Might help if you let us know, what are the shock settings on the ride, and was theire any mods made to the ride.
Old Jul 28, 2017 | 06:58 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Check tire pressures start with 30 psi up front and 36 psi in the back. The rear shocks may be set stiff. When making lane changes don't linger in the "zipper", that seam can/will grab your tire, try to cross at an angle.
I stand corrected the front pressure is 36 psi and rear at 40 psi. This on the stock tires, if tires are inflated to max sidewall pressures this could cause the bouncing you are experiencing.
Last edited by seniorsuperglideE8; Jul 28, 2017 at 10:06 PM. Reason: corrected information
Old Jul 28, 2017 | 08:58 PM
billib1954's Avatar
billib1954
Front pressure = 36, rear 40.
Old Jul 28, 2017 | 10:24 PM
Fatbobal's Avatar
Fatbobal
Tire pressure is good have checked new rear tire when I bought the bike suspension set at 2 in the rear I'm about 210 on mods are cosmetic air cleaner and pipe
Old Jul 28, 2017 | 10:26 PM
NORTY FLATZ's Avatar
NORTY FLATZ
What did you ride before?
Old Jul 28, 2017 | 10:28 PM
Fatbobal's Avatar
Fatbobal
I've been riding since I was 17 I've ridden a lot of bikes 05 fatbob was the last harley a few years back currently have the fat bob and a 08 buell 1125r
Old Jul 28, 2017 | 10:41 PM
NORTY FLATZ
Ok, gotcha. I was just wondering if this was your first cruiser. Cruiser geometry can get "nervous" at the upper speeds.
Does the bike "move around" under max throttle?
Does the bike "move around" under braking?
Move around only when you hit those raised reflectors in the roadway?
How old are your tires?
Old Jul 28, 2017 | 10:53 PM
Fatbobal's Avatar
Fatbobal
rear tire is new not really moving during bring or accelerating just seems uneasy cruising and switching lanes at 60+ and the bumps I can't explain it in typing any better I checked neck bearing bolt but I won't leave go of the bars I don't like leaving one hand off I guess I'll take it in and see what I'm told seems really odd for a practically new bike to perform the way it is
kt3k
Jun 28, 2022 03:16 PM
Cazador
Milwaukee Eight (M8)
31
Sep 15, 2018 01:29 PM
m_mcdonnell314
May 2, 2015 11:31 AM
SNFXDB
Mar 17, 2015 08:41 PM
superglide317
Feb 6, 2008 07:18 AM
