# 4833 works as both a brake light and turn sigs.. You can do away with your rear turn sigs, On the control just set theswitch... Very easy to install everythings Included 169.99
I sent mine to somebody on the board but dont rember who..... LOL
Trotter,
Pretty sure I have the 4833, will need to check my files - where is the 'control switch'? Don't recall seeing one when I had it off last week...
I put the panacea tail/turn integrated unit on my wg. I installed some hard bags and this was a great option. You do not need any other turn signals on the rear, and you only need another load equalizer if you add front led's on the circuit. I bought the smoked one, and it is the same for sg, or wg rear fenders, you just invert it and plug a jumper into the module. You can also set the brake light to come on normally, or pulse first and then steady. It's profile is also about 3/4 " shorter than the stock tailight, and tucks into the fender well. http://i157.photobucket.com/albums/t...69/bags004.jpg http://i157.photobucket.com/albums/t...69/bags003.jpg
On the supplyed control box you plug in under the seat there should be two switches one for Pulse setting, and one for Led turn sigs or standard, Set to standard.. The pic shows with load Eq also switches are on the other side
Sorry it took me so long to get back, as you already read I am running the 4833 set up the same as the others. No rear turn signals, It really clean up the back! Well worth the $
Hey! That looks like my tail light in that pic!
I am running it with the LED turn signals, But I do not see why it could not be used as a stand aloone item.
