Panecea Tail lights
Ive got an 07 Street Bob which I have removed the front turn signals and want to remove the rear signals as well... I want to use my tail light as a running\brake\turn signal... Whats the best way to do this? Ive heard in a few other threads that there has been some rumbling about the brightness of the Kuryakyn tail lights? Also this will be mu first step into LED's so the idea of load balancers and what not is foreign to me... I talked to the support guy at Kuryakyn and he said since I have removed the stock front turn signals, and want to remove the stock rear tail lights I will need to run two load balancers... Now my question is IF I need to do this where do they go? Do they connect in line somewhere? I watched the little video that they have ( http://www.kuryakyn.com/Video-Center...intVideoID=117) but am still confused as to where the TWO load balancers would go... do they go inline? does one need to be in a different spot since its replacing the front signals?
Any other suggestions than Kuryaken? And if so Im assuming Ill need to get a run\brake\turn controller?
The Panecea taillight plugs into the stock taillight and turn signal harnesses.
