Bar Install
Old Jun 10, 2007 | 08:48 PM
boa74's Avatar
boa74
Default Bar Install
Hi i have started the install of my new street slammer bars i am NOW looking at the service manual and I see the it say to put a shim between the break lever and the mount well i did not do that how would I know if I am screwed ? also were do my wires get disconected so i can run them in the bars? I am lost do I need to pull the tank?
Old Jun 10, 2007 | 08:58 PM
torchmaster's Avatar
torchmaster
Default RE: Bar Install
There's a chance of breaking the brake lite switch if ya forget the shim. Heard its a real pita to change if you do. You can check it by turning the ign switch on and if the brake lite is on without pulling the lever its broke. Got my fingers crossed for ya! Im not sure about the wiring on a dyna. On my sporty I just raised the front of the tank to get to the plugs.
[hr]
Old Jun 10, 2007 | 09:29 PM
jmpancoast's Avatar
jmpancoast
Here is a link toa write-up on an ape install done by another member. It should be great info for you.
https://www.hdforums.com/m_1328001/tm.htm
mjolnir
May 14, 2012 08:03 AM
DrkHrse
Feb 1, 2012 09:32 AM
1HD2NV
Jan 26, 2012 09:46 AM
benjamin247
Apr 17, 2010 01:20 AM
matt323
Nov 29, 2004 05:14 AM
