Probably a dumb question
Old Jun 11, 2007 | 12:56 AM
nkauf21's Avatar
nkauf21
Default Probably a dumb question
I just got my new sidemount plate in the mail. This time I'm trying an axle mount instead of my previous shock mount. When I unbolt the left axle nut to put this thing on will it affect the wheel, or will everything stay put? Should I put it on the lift? I've never pulled a wheel so I am not sure how unbolting one side will affect things.
Old Jun 11, 2007 | 08:36 PM
dailydriver's Avatar
dailydriver
Default RE: Probably a dumb question
If your just unbolting the nut and leaving the axle in place your golden...everything else stays put...Hope this helps..Later
Old Jun 11, 2007 | 09:38 PM
DGlide04's Avatar
DGlide04
Like daily said, if you're only taking the nut off, then you'll be okay. Moving the bike of adjusting the belt tensioners is another matter, that will move the axle, which is not what you want to do.
Post some pix when you get it installed.
Old Jun 11, 2007 | 10:43 PM
nkauf21's Avatar
nkauf21
Awesome, thats what I was hoping. I'll post some pics when its installed. I already had a side mount from this fabricator, but it mounted to the shock bolt and it broke off. He sent me a new one for free and this one goes to the axle. This one looks a little stronger so hopefully it wont fail. We'll see. I also bought another shock mount one from a different shop but haven't got it in the mail. I am going to compare the two and see which one seems sturdier.
Henry89
Sep 13, 2014 11:15 AM
venomous
May 8, 2013 05:09 PM
jason.tollett
Mar 16, 2013 05:11 PM
katanaplanet
Jul 19, 2012 02:53 PM
ny06fxdb
Oct 6, 2009 06:56 PM
