I don`t like the textured bars either, looks cheap. Seeing how these new softail frames are alike, except for maybe the neck, I wonder if you could install a 2018 low rider 5 gallon tank onto the 2018 SB? The mounting points should line up. Hmmmm
Definition of vibration
1 a :a periodic motion of the particles of an elastic body or medium in alternately opposite directions from the position of equilibrium when that equilibrium has been disturbed (as when a stretched cord produces musical tones or molecules in the air transmit sounds to the ear)
Vibration is a mechanical phenomenon whereby oscillations occur about an equilibrium point. The word comes from Latin vibrationem ("shaking, brandishing"). The oscillations may be periodic, such as the motion of a pendulumor random, such as the movement of a tire on a gravel road.
Vibration can be desirable: for example, the motion of a tuning fork, the reed in a woodwind instrument or harmonica, a mobile phone, or the cone of a loudspeaker.
In many cases, however, vibration is undesirable, wasting energy and creating unwanted sound. For example, the vibrational motions of engines, electric motors, or any mechanical device in operation are typically unwanted. Such vibrations could be caused by imbalances in the rotating parts, uneven friction, or the meshing of gear teeth. Careful designs usually minimize unwanted vibrations.
I took an 18 Fat Bob for a demo ride a couple of weeks ago. The main thing I came away with was I might be able to get used to the noise the engine made, but it's kind of iffy.
I wouldn't describe it as a knock knock, but it sounded to me like it had some bad bearings in the bottom end. One of the Harley guys there said it was the balancers. It could be. All I know is if one of my bikes sounded like that I would be very concerned.
The balancers are gear drive. Straight cut gears. There is going to be some gear noise and lash. This might be the source of the "knock knock".
Those balancers are completely wrong-headed from my perspective. If MoCo wanted a smoother engine, they should have altered the V angle and crank geometry, not add mass and unnecessary complexity. I bet an M8 with a basic evo-style crankcase would be a MONSTER. Of course, it would still be a paint shaker...and the focus group idiots said that was BAAD. :/
Want to call it knock knock or whatever you like, I call it the fake vibration.
It's all by design.
The Milwaukee-Eight is counterbalanced. The balance factor, for the nerds among us, is 75 percent. Bozmoski explained that non-native Harley riders seemed to like things smoother than their bar-and-shield brethren, but when the engines were completely balanced, The Faithful didn’t like it one bit. At this juncture, I think I should mention that I think Bozmoski was neurotic about this point; he’s a former NVH guy.
“Harley riders like the bikes to shake a little bit and put on a show at the stoplight,” he explained.
Our test bikes were very mellow. The mirrors shook a little at idle, but that was about as dramatic as it got. Bozmoski says the counterbalancer smooths low-engine-speed vibration, typically under 1,800 rpm or so. Rubber-mounting the engine comes into play for the higher rpm vibrations. This two-pronged approach to dealing with vibration works! This is the smoothest Harley Big Twin I’ve ever felt, and I bet our readers say the exact same thing.
