03 fxd reading no oil
Old Oct 19, 2017 | 06:02 PM
F86's Avatar
F86
Originally Posted by 71on72
What type of oil do you use?
The transparent kind, obviously!
Old Oct 19, 2017 | 06:44 PM
TriGeezer's Avatar
TriGeezer
Make sure you are checking it properly.
- remove dip stick
- wipe it off
- reinstall dipstick...and screw it all the way in.
- remove it carefully, and take the reading at the proper scale for "on jiffy stand" or "vertical" as appropriate.
Old Oct 19, 2017 | 06:53 PM
F86's Avatar
F86
Also, keep in mind that the "Full" mark indicates the correct level at full operating temperature, on the side stand. You can check it cold (which is easier), but keep in mind that roughly halfway between "Add" and "Full" will be about full when warmed up fully (at least on mine).
If you're checking it cold, it may not actually be quite as low as you think...
clackavosticus
Mar 23, 2017 05:11 PM
KeeBee
Oct 8, 2014 07:03 PM
harley1584
Mar 19, 2012 07:17 PM
King Kobra
Jul 8, 2007 10:17 AM
Anthony8858
Oct 2, 2005 09:51 AM
