Drag bars
Old Nov 7, 2017 | 04:15 AM
Shivike Thor's Avatar
Shivike Thor
6th Gear
Default Drag bars
Quick question. Is it possible to swap out the original bars for a set of drag bars using original risers? Bars I am thinking about are 790mm wide with 90mm pull back. (Divide that by 25.4 to get imperial). I am not sure if they will hit tank or not?
Old Nov 7, 2017 | 04:50 AM
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
One way to find out...install
Old Nov 7, 2017 | 02:58 PM
Shivike Thor
6th Gear
Yep that was the plan, but thought before i spent the money someone might have tried it before....
Old Nov 7, 2017 | 04:01 PM
DynaKid94's Avatar
DynaKid94
how tall are your stock risers? could make a quick mockup with some pvc to test fitment if you're worried about clearance...
Old Nov 7, 2017 | 11:53 PM
Shivike Thor
6th Gear
That's great advice thank you. Stock risers only about 2" (haven't measured). But also thanks to the mods for under $50 post I have found the way to increase riser height without spending **** loads. So the good thing about your suggestion of using pvc is great as I can try straight and then also pull back to see what I like best. So first I will try straight then will heat and try pull back.
Old Nov 8, 2017 | 01:03 PM
JoshFXDL's Avatar
JoshFXDL
So wild1 makes several different drag bars with the risers built in, they are very clear about what their rise, pull back, etc. are.
It was a pretty easy swap for me and did not require lengthening any cables/wires.
The quality of the bars was beautiful too.
http://www.wild1inc.com/
Old Nov 8, 2017 | 01:10 PM
JoshFXDL's Avatar
JoshFXDL
I currently have the WO560 with 5" rise, 14.5" pull back, 30.5" wide and 25 degree wrist angle.
I'm a little over 5'8" and the pullback is comfortable but I think I could go forwards a little bit...
I'm considering picking up some WO507 which are 10" rise, 30.5" WIDE, 12-1/2" PULL BACK 25° WRIST ANGLE...I think they might look a little cooler and be perfect.
Old Nov 9, 2017 | 04:44 AM
Shivike Thor
6th Gear
cool will check that out
Old Nov 9, 2017 | 09:22 PM
thatguy16's Avatar
thatguy16
I was in your same boat with my Street Bob. Instead of spending a bunch of $$ on new stuff I found a set of lowrider-s take-offs for $50 locally and swapped. Good luck!!
Old Nov 10, 2017 | 01:47 AM
Northbound Southerner's Avatar
What bike and risers? Some of the Harley risers have a larger inner diameter and won't work with regular bars...
dazzlyn
Oct 8, 2012 01:41 AM
VETERAN75
May 2, 2012 06:18 PM
crawly
Jun 1, 2010 01:05 AM
sledhead140
Aug 29, 2008 07:32 PM
Screamin00
Jun 1, 2008 12:21 AM
