Dyna front end
Old Dec 15, 2017 | 05:23 PM
maduxfn31's Avatar
maduxfn31
Default Dyna front end
Does anyone know if a front end on a 1995 low rider would fit a 2000 wide glide
Old Dec 15, 2017 | 05:48 PM
crusader1xxx's Avatar
crusader1xxx
Yes, it will, frame change was 2006 so anything earlier then that will work
Old Dec 16, 2017 | 08:42 AM
sharkey's Avatar
sharkey
1995 Low Rider would have had 39mm forks; Wide Glide in 2000 would be 41mm forks. A parts book would tell you if the bearings are the same
Old Dec 16, 2017 | 09:56 AM
Jay Guild's Avatar
Jay Guild
The neck is the same though so as long as the front end comes with the triple trees it should fit.
Old Dec 16, 2017 | 10:53 AM
fxdlx's Avatar
fxdlx
Your front brake caliper won’t bolt on
Old Dec 20, 2017 | 09:13 PM
TexasScooterTrash's Avatar
TexasScooterTrash
There are 4 piston calipers for Twin Cam bikes with Evo fork bolt patterns. Did that brake upgrade on my Wife's old 94 XLH 1200. Easy job and fantastic improvement in breaking.
Old Dec 21, 2017 | 01:32 PM
Carl '69's Avatar
Carl '69
HD made at least 2 different 4-pot calipers in that year range- one for the 39mm FX forks & 41mm FLST forks & one for the 41mm FXDWG & FXST forks. I know for certain the 41mm FXxxx trees are a bit wider than the 41mm FLST trees.
ThumbsUp20
EVO
Apr 10, 2020 08:15 AM
Pinetop
Aug 13, 2012 10:20 AM
Titan56
Jan 2, 2011 12:16 PM
caballero_81
Nov 2, 2010 02:58 PM
