Obnoxious Oscillating Hum....
Old Jan 24, 2018 | 02:33 PM
wingrida's Avatar
wingrida
Thats the Dynamo Hum that Frank Zappa sings about.
Old Jan 24, 2018 | 02:52 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
May be tinnious. Does it quite when you stop? On a serious side, can't believe I am say this but your exhaust is too quite.
A shot of talicum on the belt will act as a short term lubrication to eliminate that as the reason. Too clean a belt will make a noise if you are on a narrow street between buildings.
Old Jan 25, 2018 | 01:10 PM
The cannibal's Avatar
The cannibal
Gotta love that dynamo hum
Old Jan 25, 2018 | 06:50 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
My Road Glide Ultra seems to hum to me also but in a lower key, because it's heavier? Seriously, sounds like tire noise in the curves.
Old Jan 25, 2018 | 07:21 PM
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
...and ******* and beer
Old Jan 25, 2018 | 09:03 PM
TexasScooterTrash's Avatar
TexasScooterTrash
I guess your dynamo mumms because it can't remember the words.
Old Jan 26, 2018 | 06:38 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Laced wheel(s)?
Or brake rotor/pad noise.
Or tire tread unevenness.
Old Jan 26, 2018 | 07:26 PM
Huggerbugger's Avatar
Huggerbugger
Replaced tires. Still hums. They're balanced. Checked tire alignment, it's good. The noise is related to speed and increases on curves.
Old Jan 26, 2018 | 09:50 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Because you said it is on two of your bikes: do you do your own adjustment on the belt tension? Belt too tight or belt too loose perhaps. Try cleaning the sides of your belt and take it for a ride. Too tight and it may be strumming like a guitar string. The engine alignment changes because the way it sits on the rubber mounts in relation to the rear swingarm. I doubt your bearings on both the bike would be going bad unless you did something to both of them at the same time.
Old Jan 26, 2018 | 10:35 PM
Huggerbugger
I keep thinking it's the belts, too. They're tight but flex enough per the markings on the belt guard. Maybe not aligned perfectly.
