06 FXDI shifter won't return
Old Mar 10, 2018 | 05:10 PM
jdaulton3's Avatar
jdaulton3
Default 06 FXDI shifter won't return
I had just made a new shift rod using QA1 heim joints and cold rolled steel to replace the stock ball joint rod. The bike has forward controls.
After replacing the rod, the shifter is not returning to center and I've got to move it with my foot to get centered.
I noticed the heim joints are really tight; not sure if how loose they should be but I had to put a fair amount of force into them to get them to move. I also think the overall assembly is about 1/8" longer than the original.
Any ideas on what might be the issue? If worse comes to worse I can always put the old rod back on...
TIA
Old Mar 10, 2018 | 05:49 PM
jdaulton3's Avatar
jdaulton3
never mind... just looked at it again and realized that I had the helm joint on the wrong side of the lever.
clap
Nov 4, 2016 05:07 AM
INJEKTER
Sep 12, 2015 06:33 PM
seamus
Mar 14, 2014 04:29 PM
Dieselhed
Jan 7, 2010 03:55 PM
Demonsmasher
Mar 27, 2008 09:29 PM
