Front brake pads - No gap?
Old Mar 14, 2018 | 04:31 PM
Huggerbugger's Avatar
Huggerbugger
Default Front brake pads - No gap?
Looked at my front brake pads and there is virtually NO gap between pad and disc on the inside. Also have a hum that comes on at about 40mph and gets louder in turns. Methinks there should be a .040 gap according to the manual.
Old Mar 14, 2018 | 07:13 PM
CoolBreeze3646's Avatar
CoolBreeze3646
When was the last time the brake fluid was changed? Stuck piston in caliper? Return hole in Master Brake Cylinder plugged? When was the last time you had the caliper(s) off and checked for crud on the piston/piston seals. Just suggestions of where to look. Hope you find the issue.
Old Mar 14, 2018 | 08:53 PM
nevil's Avatar
nevil
That hum is usually generated by the holes drilled in the rotor.
Old Mar 15, 2018 | 09:03 AM
multihdrdr's Avatar
multihdrdr
No Gap is normal...There should be virtually no gap between rotor and pad material.
The .040 you refer to is the spec for minimum pad friction material thickness
...check your wheel bearings and tires
Old Mar 15, 2018 | 07:39 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 pad thickness is .04 in.
Rickr01
May 23, 2017 10:15 PM
crepe
Wheels/Tires
Apr 19, 2010 04:19 PM
SecondChance!!
Mar 23, 2009 09:57 AM
HDF Tech
Jun 28, 2005 12:49 PM
