Lube or not
Old Mar 30, 2018 | 09:51 AM
rjo3491's Avatar
rjo3491
Default Lube or not
Hey all:
Getting ready for riding season here in SE Michigan (eventually). I can't seem to get a definitive answer on whether or not to lube my clutch cable (2008 Superglide). Not sure if it's teflon or not. What are folks doing regarding this topic?
Thanks!!
Old Mar 30, 2018 | 10:11 AM
TinCupChalice's Avatar
TinCupChalice
Lubing the clutch cable is a part of my winter maintenance every year. I've always used left over transmission lubricant and drool it in to the cable from the top. I figure the bottom of the clutch cable has transmission lubricant in it, so I can't see how it's going to hurt it
Old Mar 30, 2018 | 01:28 PM
rjo3491's Avatar
rjo3491
Thanks. I figure it could prevent a broken cable out on the road - a PITA I could do without.
Old Mar 30, 2018 | 01:34 PM
cggorman's Avatar
cggorman
Dont forget the lever pivots and adjuster. I like Boeshield for stuff like the adjuster and dry lubes (like Dri-Slide or DuPont Chain Saver) for exposed pivots like at the lever. It doesn't collect grit and crap like oils do.
Old Mar 30, 2018 | 02:53 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Yup, cable maintenance is important. It also allows visual inspection of things. OP- how many miles do you have on your cable now? If >60,000 then you might look at picking up a factory cable, for when yours develops 2 ends.
Another way to extend your cable life would be to reduce the stress on it. Maybe a Burley EZ boy clutch device could help extend cable life.
Old Mar 30, 2018 | 04:38 PM
rjo3491's Avatar
rjo3491
All done. Thanks for everybody's input. Now, how do we make the weather warm up?
Old Mar 30, 2018 | 04:40 PM
Dyna7's Avatar
Dyna7
By moving to California! I am enjoying (well enjoying as much as I can from an office) the nice 80° weather we are having. While I am stuck in here today, it is going to be in the 80s all weekend, so I have a couple good rides to look forward to.
Old Mar 31, 2018 | 01:29 PM
hvacgaspiping's Avatar
hvacgaspiping
Hey all:
Thanks!!
Ask Keith.
Rocker B
Jul 5, 2019 03:03 AM
bbflhrs
Apr 20, 2012 03:28 PM
Rock Chalk
Apr 17, 2012 10:27 PM
Mike O
Feb 2, 2011 06:19 PM
asm481
Apr 26, 2009 07:42 AM
