Load regulator needed???
Old May 15, 2018 | 04:03 PM
DChaltry's Avatar
DChaltry
Stage III
Default Load regulator needed???
Hey dudes,
planning on ordering a custom dynamics license plate LED rear signal kit & joker machine front LED turn signals for my ‘09 FXDC. Curious as to whether or not I need a load regulator, and if so, one or two? Not quite positive how everything wires together.
Thanks!
Old May 15, 2018 | 04:35 PM
Krazy8s's Avatar
Krazy8s
Yes you do.
Custom dynamics have an assortment of plug n play black box equalisers, give them a call
Old May 15, 2018 | 06:07 PM
k-weaver's Avatar
k-weaver
Depends on the size of the equalizer. I did a cycle vision rear light on my '09 and they specifically told me not to use the equalizer that comes with it but instead I had to buy another one from them. This other one was physically bigger.
I tested with the smaller one to see what would happen. It worked but wasn't enough. So my lights wouldn't flash quick but id get a flashing red key in between each flash. When using the equalizer they told me to I didn't have this issue.
Months later I added custom dynamics front LEDs. I added the smaller load equalizer that I had left over, the flashing red key came back. So I know I need a bigger one.
Given my experience, you'll probably need two. Although I think you can get an adjustable one (badlands?).
Old May 15, 2018 | 09:50 PM
HrdNox's Avatar
HrdNox
Originally Posted by DChaltry
Hey dudes,
Thanks!
Yes,you’ll need one. It’s plug and play and will do all the things you’re planning.
https://www.revzilla.com/motorcycle/...rley-1996-2013
Old May 18, 2018 | 09:04 PM
DChaltry's Avatar
DChaltry
Stage III
thanks HrdNox, would that single unit be sufficient for front & back signals?
Old May 18, 2018 | 11:15 PM
HrdNox's Avatar
HrdNox
Yes. And I’m 99.9 percent sure that’s the I have. And if you cut the “ears” off it fits in the space inside the fuse box.
AussieDog
Sep 6, 2018 12:50 AM
Tim Dukery
Aug 24, 2018 07:47 AM
Nif_tea
Oct 7, 2013 02:17 AM
stormcooker
Jan 1, 2010 07:33 AM
Rocket350
Mar 14, 2009 05:24 PM
