Rockouts
Old Jun 2, 2018 | 01:46 PM
Unclescarhead's Avatar
Unclescarhead
Default Rockouts
I was just wondering if I needed rocker shaft locks. I have a 2016 wide glide .was not sure if harley ever corrected the issue before my model year .Thanks for any info .
Old Jun 2, 2018 | 01:55 PM
TwiZted Biker's Avatar
TwiZted Biker
Cheap, easy and effective fix for an annoying issue pick up a set anyway, if you don't use them you know someone who will.
Old Jun 2, 2018 | 01:58 PM
Unclescarhead
Great idea.its always nice to support an American company too. Thanks
Old Jun 2, 2018 | 02:01 PM
TwiZted Biker
I'm not affiliated in any way but I have helped a few buddies with their TC's and they do knock down the clatter considerably, can't fault what works.
Old Jun 2, 2018 | 02:23 PM
ROCKOUT Rocker Products
Sponsor
Your WG still has the Twin Cam engine, and it's associated top end noise issues.
Rockouts are the worldwide proven cure
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 2, 2018 | 03:57 PM
toddskill's Avatar
toddskill
Rockouts took out most of the noise in my 16 wide glide. But be aware it will never be totally silent, it's an air cooler engine between your legs.
Old Jun 2, 2018 | 04:54 PM
Unclescarhead
Thanks for the replies. I realize the motorcycle is mechanical and there will be noise.at what mileage does the rocker shaft noise typically begin.
Old Jun 2, 2018 | 05:29 PM
Sponsor
Could be day 1, could be at 50k.... depends on a whole lot of variables at factory assembly.
Old Jun 2, 2018 | 10:14 PM
Nickd2689's Avatar
Nickd2689
i honestly don’t remember when mine started but I know it wasn’t long after I bought the bike. I’ve had a horrible noise in my top end (22k miles) and I suspect this is the issue. I ordered rockouts for mine and should be installing them tomorrow. They only come with 5 which is for the two bolt holes on each cylinder that the rocker shaft is against the bolt hole, plus a spare, but I bought two sets and am considering installing them in each hole. Either way I’ll post back and let you know the results.
Old Jun 2, 2018 | 11:57 PM
multihdrdr's Avatar
multihdrdr
Only 2 bolt holes per support plate intersect the Rocker Shaft Bores... (or if you prefer, 1 bolt hole per shaft bore intersects)
