Stator Repair
Old Jun 17, 2018 | 05:06 AM
cato_edin's Avatar
cato_edin
Stage III
Hi Trench. Is your stator/rotor still for sale and can You ship it to Norway ??
Cato
Old Jun 17, 2018 | 10:30 AM
green hd's Avatar
green hd
Just replaced the stator on my cvo dyna this week. Make sure you loc tite all bolts!!
Old Jun 18, 2018 | 09:08 AM
archergodwin's Avatar
archergodwin
I think there's a method to upgrade to a 07 and newer rotor...
Old Jun 19, 2018 | 01:23 PM
shovelheadroad's Avatar
shovelheadroad
Originally Posted by slippin_jimmy
I have a 2006 Dyna Wide Glide. Got stranded over the weekend and now I have the primary apart after checking everything out first. The rotor bolts have backed out causing stator failure. Maybe a stupid question, but having an 06 with 32k on it, would the MOCO reimburse for the parts or is it too late? I needed a battery anyway so I went ahead and replaced that and the VR too. Anyone have any experience with an older bike? It is a terrible design and I think they should stand behind that.
I'm in the same boat. Mine blew up last weekend, too. Did you have to remove the inner primary to remove the rotor/stator?
Old Jun 19, 2018 | 02:49 PM
cato_edin's Avatar
cato_edin
Stage III
Hi Shovelheadroad. No. You only need to remove the outer primary ( if it's the same as the Street Bob).
Don't have to remove the cluttch either.
Cato
Old Jun 20, 2018 | 08:19 AM
slippin_jimmy's Avatar
slippin_jimmy
I did because of a lip in my inner primary. I'm glad I did because my shift lever was loose. If you need to take off inner primary, take your battery box out first. Makes for an easier job getting those hex nut starter bolts out. Pretty straightforward jobber though.
Old Jun 20, 2018 | 12:14 PM
shovelheadroad
I've been down that road swapping my wideglide's IPB for the baker bearing a couple of years ago. I used a super long allen wrench to loosen the starter. Didn't learn about the '06 rotor issues till after I buttoned it up of course. I was hoping somebody could tell me if there was a shortcut. Going to find out anyway I guess, lol.
Old Jun 20, 2018 | 02:08 PM
slippin_jimmy
Some guys including a buddy of mine used a dremel tool to take the lip off from the bottom of the case. Mine was rubbing at the 8-10 o' clock position too, so I said the hell with it and took off the inner primary. I didn't do the bearing as mine was in good shape. If the bearing does go, I'll take it apart again. I don't mind an excuse to escape to the garage once in a while.
Old Jun 21, 2018 | 01:02 AM
shovelheadroad
I think I'll give the dremel method a try if at all possible. It's all about riding time for me...plus I'm a lazy bastard. Iol.
Buffalo7
Electrical/Lighting/Alarm
Sep 25, 2017 03:17 PM
Buffalo7
Sep 18, 2017 07:20 PM
fpe5
Jul 7, 2017 11:49 AM
dogcop727
Oct 11, 2010 02:05 PM
bigheaded2
Sep 29, 2009 08:07 AM
