drive belt replacement
Old Jul 3, 2018 | 09:17 PM
philthyone's Avatar
philthyone
6th Gear
Thumbs up
Originally Posted by GREENOHAWK69
If you plan on changing the belt, don't be intimidated about never doing it before. Neither did I on my 97 Wide Glide and it was not a problem. I bought a new 3-phase charging system and installed that at the same time. Follow the manual and there are kits you can purchase that will have the appropriate bolts, etc. - I just googled. The primary chain locker is a delrin "step" looking device that works great. Breaker bar and using the extension on your floor jack made it easy to get the compensator off. The torque value to re-install on my 97 was 150-165 foot/lbs, and I did have to buy a new torque wrench for that.
My workshop manual clearly states "Do not use" step looking device you mentioned? I'll used a lump of wood about 8" long by 1"X1/2 to unlock and lock compensator and clutch nuts. I saw a guy use the wood on you tube,thats how I got the idea. Worked fine for him?
Old Jul 7, 2018 | 11:53 AM
GREENOHAWK69's Avatar
GREENOHAWK69
My Service Manual for 97 & 98 Dyna clearly states to use the primary stepped locking tool. See page 6-6 and the attached pic.
Old Jul 13, 2018 | 10:33 PM
S&S145's Avatar
S&S145
CONVERT To a 530 O-Ring Anodized chain and a 23./24 Tooth Front transmission Sprocket By BAKER DRIVETRAIN and a Rear 51 or 52 Rear Tooth Sprocket & get rid of that belt and all those hassles forever .
Old Jul 13, 2018 | 11:42 PM
Kingglide549's Avatar
Kingglide549
Chains are a LOT of maintenance.
People that grew up with belts have no idea how good they have it!
Old Jul 14, 2018 | 04:15 AM
cutter4292's Avatar
cutter4292
Thumbs up
Chains are more trouble than there worth. I'll take a belt anytime.
Old Jul 14, 2018 | 04:18 AM
Kingglide549
I rode an Iron head coast to coast and more.
The chain is a daily and ritual.
Pothole914
EVO
Jun 3, 2015 03:05 PM
JimGnitecki
13
Apr 3, 2014 10:45 AM
hoggy05
Apr 12, 2013 10:17 PM
Retrop
Feb 24, 2013 11:19 AM
Hog Yild
Jul 26, 2011 06:21 PM
