Rough Idle
Old Aug 25, 2018 | 03:13 PM
Huggerbugger's Avatar
Huggerbugger
Default Rough Idle
'09 Dyna bounces vertically a lot at idle. Motor mounts are new. Replaced all sensors, but not the IAC. Cleaned the IAC, but no appreciable effect. Injectors are new. Replace the IAC?
Old Aug 25, 2018 | 03:36 PM
F86's Avatar
F86
If you mean there's visible engine vibration and movement at idle but it smoothes right out with a little bit of throttle, that's the normal behavior of rubber-mounted Twin Cams... Is it fine once you're riding?
Old Aug 25, 2018 | 04:08 PM
cggorman's Avatar
cggorman
All stock?
Condition and quality of tune (including idle speed!) as well as any aftermarket mods (including pipes!) can greatly affect idle quality.
Old Aug 25, 2018 | 04:44 PM
Huggerbugger
Stock. Idles like a ditch pump. Didn't used to.
Old Aug 25, 2018 | 06:19 PM
JohnMn's Avatar
JohnMn
Honestly? All that doesn't mean crap if you got stuck with cheap/bad gas. (too much ethanol?)
Seahorse
Feb 21, 2019 07:49 AM
gbuss5
Aug 30, 2015 08:10 PM
W.P.
Jun 21, 2012 12:50 AM
halfbreed
Jun 8, 2009 08:04 AM
Willy G.
Apr 8, 2009 07:02 AM
