Best Pullback Risers for Pro Taper bars
Old Sep 16, 2018 | 12:53 PM
bucket13's Avatar
bucket13
Default Best Pullback Risers for Pro Taper bars
What are your thoughts on the best pullback risers with internal wiring? Looking for about 7-8" high with 2" pull back, that accommodate 1 1/8" protaper bars.
Old Sep 17, 2018 | 04:59 PM
TOE_CUTTER's Avatar
TOE_CUTTER
Kraus.
Pricy though.
Dave
Old Sep 17, 2018 | 05:49 PM
bucket13's Avatar
bucket13
Originally Posted by TOE_CUTTER
Kraus.
Pricy though.
Dave
Yes, love them ... only problem other than the $, is that you can't run the wiring internally.
Old Sep 17, 2018 | 06:15 PM
TOE_CUTTER's Avatar
TOE_CUTTER
If you are talking about the difference between having the wiring coming out of the bottom of the handlebars or coming out of the risers a little bit closer to the trees, I really do not think visually you’re going to see very much of a difference. I still have my stock handlebars on my LRS, and with the 6 inch risers with the wiring coming down from the center of the handlebars, you can barely see the wiring. With those Kraus risers, you’ll have even less visible.
My .02,
Dave
Old Sep 17, 2018 | 07:07 PM
bucket13's Avatar
bucket13
My .02,
Dave
Good point Dave ... I'm going to do a google search for an image of the Kraus risers mounted.
Old Sep 17, 2018 | 07:54 PM
Bob_fxdb's Avatar
Bob_fxdb
Im already running biltwell murdocks risers on my dyna with 1" bar. My plan is to swap to a 7/8" pro taper bar in the winter in still using the same risers with conversion shims. 1" -> 7/8". I know its not 1 1/8", but maybe something look at? I dont know if it looks pretty or not with the shims, but i dont think i will notice it. Just a suggestion
Old Sep 17, 2018 | 10:20 PM
neverstockjp's Avatar
neverstockjp
Look up forbidden motorcycles
2ndTink
May 26, 2018 08:36 PM
Juggerpops
Sep 6, 2014 09:13 AM
f3fidy
Apr 14, 2013 08:18 PM
PUBA ONE
May 1, 2008 07:48 PM
sportncruise
Mar 13, 2008 04:27 AM
