Pre-CAN "check engine" light?
Old Sep 17, 2018 | 08:50 PM
cggorman's Avatar
cggorman
Default Pre-CAN "check engine" light?
Anybody know what conditions trip a check engine light on a non-emissions, carbureted pre-CAN bike?
I've never seen mine light up and I'm debating if I should bother wiring it up with my custom setup. It Will take some diodes and effort that I'm not sure will have any benefit.
Old Sep 17, 2018 | 09:08 PM
crusader1xxx's Avatar
crusader1xxx
Crank position sensor for timing? Only thing I can think of off the top of my head.....might cause the light
Old Sep 18, 2018 | 12:15 AM
F86's Avatar
F86
I've wondered this same thing.
Mine came on a couple of times shortly after my engine build, while I was chasing a noise in the cam chest. The Check Engine light would come on if the engine had been running for a bit. I found a bad cam chain (which I had idiotically reused). Once fixed, the light never came back on again.
Old Sep 18, 2018 | 01:18 AM
cggorman's Avatar
cggorman
Sounds like building the circuit to make this work on my setup is a wasted effort. I'll seal off the lead (black w/ yellow stripe) and make a note to revisit whenever I do the Thunderheart ignition.
bullin82
General Topics/Tech Tips
Jul 6, 2017 01:13 PM
G wizz
Jul 29, 2011 05:05 PM
pbalcer
Jun 7, 2011 05:43 PM
RoadKingHellas
Aug 31, 2010 02:25 PM
kevdog
Apr 8, 2008 06:29 PM
