Hey everyone. I have a 14 street bob. A few days ago I had to remove the pipes to fix a crack and replace a stud. When I re-installed the pipes and ran the bike, the check engine light came on. When I checked the codes I got a laundry list of them. The only thing that was done was remove pipes and installed same exact pipes. No changes where made during this fix. Any information would be great.
list of codes:
P0031 Front HO2S low/open
P0134 Front Oxygen Sensor Inactive
B1101
B1151 Bank Angle Sensor(BAS) Short to Ground
B2132 High beam output shorted high
B2137 Low beam output shorted high
B2152
B2156 Right rear turn signal output open
B2201 IGN switch off w/VSS
U0100 Lost comm w/ECM
Nope, only removed rear from pipe. Front stayed in and just unplugged. Did the same thing last time when pipes removed to put new gaskets from pipe to jugs and re-paint heat shields. Replaced rear O2 sensor and cleared codes. None returned. But rear O2 sensor wires go jacked up when removing. This time didnt mess with the wires.
