Fxdb to fxdl ignition switch
Old Oct 23, 2018 | 09:16 AM
Prkchops's Avatar
Prkchops
Stage II
Default Fxdb to fxdl ignition switch
I've tried searching for this but can't quite seem to find a clear answer. I'm trying to convert my 2017 fxdb dash to a fxdl dash. I have found the sub harness from fxdl that will plug into the fxdb sub harness. Since the ignition switch on the fxdb is built into the sub harness and the fxdl is not how would I go about relocating my ignition switch from my fxdb to the horn location? I've looked at both model wire diagrams but can't find the ignition switch wires for the fxdl. Any help will be appreciated and sorry if this is a repost
Thanks
Old Oct 23, 2018 | 10:23 AM
kcfocust's Avatar
kcfocust
My brain might not be working, but wouldn't the ignition wires be housed on the frame for the fxdl, the fxdl ignition and column lock are part of the same, granted mine is a 2009
Old Oct 23, 2018 | 10:28 AM
Prkchops's Avatar
Prkchops
Stage II
You are correct, although I have seen some fxdl models with the ignition switched mounted where the horn goes on the fxdb. So I'm curious if I just depin my current sub harness and extend them to either the horn area or the neck lock. Thanks for the reply
Finn696
Sep 3, 2016 10:00 AM
dirt41
Sep 17, 2015 07:01 PM
crawfordcl
Sep 15, 2010 10:52 AM
jay3yzfr6
Aug 31, 2010 02:21 PM
781/2fxs
May 13, 2009 11:24 PM
