Not at all difficult. De-pin the stock fuel connector and insert new harness pins in stock plug housing (after running it through the tank tube). Gas cap just has a 3M tape trim ring to apply. The Dakota is just plug and play. For someone on a budget, just adding a black gauge bezel over the stock chrome bezel is a cost affective black-out option. The ignition again is just plug and play. I went to the dealership and ordered the 3M trim ring for it, and rattle canned it black. You'll never get that stock one off without bending it, because it's very thin.
Awesome. Looks like a good start. What are the plans. I'd say upgrade the suspension some if you like to push things a little harder in the corners.
Thanks! Lots of plans for this winter. 23" fat spoke wheel up front, 200 wide tire kit for the rear, 5 degree wide glide trees to get a 23 wrap fender to fit, new calipers, different forward controls, and custom designing my own handlebars.
for the silver ring around the ignition you aid that you ordered the 3m trim ring for it. was it just a sheet of the 3m or was it a cutout of the ring? if a cut out of the ring do you know the part number for it and how much did it cost? im looking into blacking out my ignition and I havnt found anything to black out the silver ring.
I don’t think I saved the package with the part number, but I’ll look for it. But I just went to the dealership and had them look it up. I can probably call them and see if they can look it up in my order history. It is just a thin piece of metal that has 3M tape, and says Off/Acc/IGN. Rattle can it black and stick it on. Nice thing is the one that is there stock is recessed down a little, and adding another one brings it almost flush with the ignition switch base.
I dont think I saved the package with the part number, but Ill look for it. But I just went to the dealership and had them look it up. I can probably call them and see if they can look it up in my order history. It is just a thin piece of metal that has 3M tape, and says Off/Acc/IGN. Rattle can it black and stick it on. Nice thing is the one that is there stock is recessed down a little, and adding another one brings it almost flush with the ignition switch base.
