FatBob Ready for Pick Up
Old Jan 11, 2019 | 02:22 PM
  #81
Huggerbugger's Avatar
Huggerbugger
The bike's running worse than it ever has. Like a jack-hammer. It's a sad commentary when you take a bike to an "Expert" and get it back in worse shape than it was.
Old Jan 11, 2019 | 02:31 PM
  #82
F86's Avatar
F86
What did Tatro actually say? Did he say it vibrates like crazy but he can't figure it out? Did he say it's running properly? Does he acknowledge the vibration as an issue, or does he say it's performing as it should?
Old Jan 11, 2019 | 03:11 PM
  #83
Huggerbugger
The crank assy he put in is defective. It literally shudders at all speeds.
Old Jan 11, 2019 | 09:12 PM
  #84
F86's Avatar
F86
But what is Tatro actually saying about it? Does he disagree with your diagnosis of a "defective crank," or does he think there's a problem with it?
Old Jan 11, 2019 | 09:38 PM
  #85
crusader1xxx's Avatar
crusader1xxx
Somehow I don’t think we’re getting the whole story on this....information is all one sided and not the side the forum members require to provide a proper response...
good luck...
Old Jan 12, 2019 | 12:04 PM
  #86
Huggerbugger
Unhappy
You're getting the whole story. It's a fiasco.
Old Jan 12, 2019 | 05:49 PM
  #87
Huggerbugger
He came out and cleaned up the engine with S-100. But the vibration is so bad after 15 miles your hands and feet are numb. Unacceptable.
Old Jan 12, 2019 | 05:53 PM
  #88
cggorman's Avatar
cggorman
When you took the bike to him, what EXACTLY did you ask him to do?
Was it more like, "change the crank"? Or "fix the vibration"?
One opens the door to reparations. The other closes it...
Old Jan 14, 2019 | 06:51 PM
  #89
crusader1xxx
So to follow up…what was the conversation you had with Tatro? I am assuming you had one, any competent mechanic would want to know the history of the bike as well as what has been done to it prior to him/her working on it.
Should have gone something like this:
Hi, I’m, insert name here, and I have a Fatbob which is having some vibration issues. It has always had a nasty vibration which I am trying to figure out. I know my bike is not operation correctly as I have ridden a few other Fatbobs and mine feels like a paint shaker compared to them.
I have been to a few other mechanic’s to try and fix this issue with no positive results. So far we have changed out the Motor mounts front and back and (add details of what has been done to try and correct the problem). You have been highly recommended so I am hoping you can help me.
Tatro:
Sure when can you bring the bike in or (depending on circumstances) sure can I take it for a ride? Rides the bike and says …..”yes there is something wrong” or no “bike seems to be running fine”….
Then moves into fixing the problem…and keeping you informed along the way…like hey I measured your flywheel run out and its way out of spec. I can rebuild them or you can replace them with quality units from SS etc. It’s a complete motor rebuild so can I recommend upgrading some other parts while we are in there, like you lifters, pushrods maybe even adding a cam to it…. etc etc?
Probably went more like this:
Hay my POS Harley is ****ed, it’s a POS and I can’t sell it, no one wants it… ..it’s been to a 100 ****ing mechanics and they were all ****ed cause no one can fix this POS. The flywheels are ****ed, I know it, how much to replace the flywheels cause that’s the cause of my vibration cause I changed out the ****ing motor mounts and it didn’t cure ****. So change the flywheels cause that’s the problem …
Tetro
Um…ok change flywheels if you say so…but it probably won’t cure your problem…
Too bad Tetro was not on this forum, would be a hoot to hear what he would have to say....
Huggerbugger……???? Honestly I am just poking a little fun at your expense but come on we only want to help you...
Old Jan 14, 2019 | 07:17 PM
  #90
Huggerbugger
Bike runs like ****, and no odometer.
