Post 2012 dyna exhaust on a pre-2012 dyna
Old Jan 20, 2019 | 12:57 PM
itsTHATnick's Avatar
itsTHATnick
5th Gear
Default Post 2012 dyna exhaust on a pre-2012 dyna
I have seen numerous articles across numerous mediums describing putting old 18mm exhaust systems on new 12mm platforms with relative ease.
What I was wondering was if that could be done in reverse. Given California's new exhaust DB laws, my desire to move back has be concerned about the V&H Side Shots that were on my bike when I bought it, so I am looking for a used option to go on my 09 Super Glide. The only thing I have been consistently finding is pre-2005, Softail, or 2017. I am perfectly willing to put a 2017 pipe on my bike (Found a Low Rider S pipe for 50obo) but I don't know if it would even work.
Any direction would be much appreciated, thanks!!
Old Jan 20, 2019 | 02:32 PM
crusader1xxx's Avatar
crusader1xxx
2006 and up should work on your 09. As for the O2 plugs, any muffler shop can mod these to which ever size you need...
Old Jan 20, 2019 | 03:11 PM
itsTHATnick
5th Gear
Okay. So, to take this a bit further, would it be possible to use 12mm O2 sensors on my 09 or would the ECU not register them?
Old Jan 20, 2019 | 06:24 PM
DynaKid94's Avatar
DynaKid94
From my (small) understanding I don't think the 12mm ones are backward compatible.
Old Jan 20, 2019 | 06:39 PM
brownie4412's Avatar
brownie4412
You can make tthem fit with a reducer, whether or not they’ll “register” with your ecu I can’t tell you. But given the fact that most Dyna pipes are listed as for 99-05 or 06-17, I think it’ll work. Another option is a tuner that’ll make your o2 sensors open loop, then just plug the holes.
Here’s a link to a reducer.
https://www.amazon.com/Innovate-Motorsports-3835-Motorcycle-Wideband/dp/B001QFL8LI/ref=asc_df_B001QFL8LI/?tag=hyprod-20&linkCode=df0&hvadid=312765622753&hvpos=1o1&hvnetw=g&hvrand=3716789959653079360&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1012954&hvtargid=pla-570271684949&psc=1 https://www.amazon.com/Innovate-Motorsports-3835-Motorcycle-Wideband/dp/B001QFL8LI/ref=asc_df_B001QFL8LI/?tag=hyprod-20&linkCode=df0&hvadid=312765622753&hvpos=1o1&hvnetw=g&hvrand=3716789959653079360&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1012954&hvtargid=pla-570271684949&psc=1
Old Feb 3, 2019 | 09:38 AM
dannyboy910's Avatar
dannyboy910
use the bung adapters to change from a 18mm to a 12 mm
Old Feb 3, 2019 | 10:21 AM
multihdrdr's Avatar
multihdrdr
He needs to go the "other" way
Old Feb 3, 2019 | 04:53 PM
mcwarren's Avatar
mcwarren
See my post from a couple of years ago at https://www.hdforums.com/forum/dyna-...n-my-fxdc.html
to see how I handled this issue. I put Vance and Hines Switchback Duals for a 2012 FXD on my 2010 FXDC and have been running this setup trouble free since. I hope this info proves helpful in your case.
sorensentyler
Oct 14, 2018 06:22 AM
majoIT
Aug 21, 2012 08:05 AM
wwb
Nov 21, 2009 05:27 PM
baggerider
Sep 17, 2008 05:53 PM
jmbear328
Feb 1, 2007 10:09 PM
