Primary leak
Old Mar 19, 2019 | 12:26 PM
Rocktorcher's Avatar
Rocktorcher
Default Primary leak
Getting ready to tear down my primary to replace inner primary seals and the trans oil seal. Any tips, tricks, or thoughts out there to help me along the way? It should be fairly straight forward, but there's a ton of experience on the forum! Thanks in advance.
Old Mar 19, 2019 | 12:39 PM
fxdlx's Avatar
fxdlx
Electric impact wrench for the comp & clutch hub nut. Right hand threads on the comp sprocket and left hand threads on the clutch hub. I have used a piece of 2X4 cut in the shape of a wedge to bind up the primary chain at the comp & clutch gears when torquing on the nuts.
Old Mar 19, 2019 | 01:19 PM
Jay Guild's Avatar
Jay Guild
If you've ever thought about doing a pulley swap, now's the time.
Old Mar 19, 2019 | 01:23 PM
Harleywashboy's Avatar
Harleywashboy
Also a good time to re-evaluate belt condition. Unusual wear, cracks, etc; if you even think it needs to be changed, this is a great time to do it.
Old Mar 19, 2019 | 02:14 PM
Krazy8s's Avatar
Krazy8s
Further to that, pull the clutch and pulley and inspect anyway. Splines on my pulley disintegrated around the 35K mark, but would never have known had I not pulled it when I swapped out rear pulley and belt.
Old Mar 20, 2019 | 07:26 AM
archergodwin's Avatar
archergodwin
Originally Posted by Krazy8s
.....Splines on my pulley disintegrated around the 35K mark, but would never have known had I not pulled it when I swapped out rear pulley and belt.
OP doesn't have the auto-adjuster, so most likely will not be an issue. The fractured splines on the inner side of the clutch hub, are more prevalent / associated with having the auto-adjuster. I tried a Hayden for a few thousand miles, but didn't like it. Have a Baker in there now... just fine.
Old Mar 20, 2019 | 09:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Since you are in there anyway...you might as well replace all the seals.
On the inner primary cover:
Primary bearing oil seal (item 13)
Starter jackshaft oil seal (item 14)
http://partsfinder.onlinemicrofiche....CASE%20HOUSING
On the transmission:
Shifter shaft oil seal (item 19)
http://partsfinder.onlinemicrofiche....TER%20ASSEMBLY
Quad seal (item 15)
Big oil seal (item 17)
Pulley spacer (item 23)
http://partsfinder.onlinemicrofiche....0SIDE%20COVERS
Mainshaft- Main Drive Gear oil seal (item 4), this seal is commonly overlooked, it goes into the end of the main drive gear and seals the space between the mainshaft and the main drive gear, very important to replace this seal (see pic).
http://partsfinder.onlinemicrofiche....ISSION%20GEARS
Old Mar 20, 2019 | 10:23 AM
Rocktorcher
Thanks for all the great info guys! The info that Dan89FLSTC provided is great, with pics even. Thanks man!
Old Mar 20, 2019 | 10:30 AM
Max Headflow's Avatar
Max Headflow
Use a jam bar and not a wedge to loosen and torque the clutch and crank nuts.
Old Mar 20, 2019 | 12:25 PM
fxdlx's Avatar
fxdlx
Max Headflow, do you think the wedge blocks put too much stress on the primary chain? Just wondering. I've tried the jam bars. You need different ones for the FLH and the FXST?
