Motor mounts
Old Apr 7, 2019 | 02:05 AM
rogersachs's Avatar
rogersachs
Default Motor mounts
Planning on replacing my front and rear motor mounts . Have 34,000 miles on my 2013 Dyna Street Bob.
Which brand would be recommended.
Thank You,
Old Apr 7, 2019 | 08:52 AM
Mutineer's Avatar
Mutineer
Thank You,
if you’re a regular style rider (no wheelies) - Predator mount. I swapped over from a blown out oem mount with 45,000mi and it was night and day difference. No longer does it try to follow tar snakes, or get the death wobble. Install was like 30mins and super easy. Worst part was waiting for the loctite to cure.
Link to referenced mount:
https://www.predatorvcs.com/harley_d...t_engine_mount
Old Apr 7, 2019 | 10:20 PM
toddskill's Avatar
toddskill
Old Apr 8, 2019 | 02:34 AM
rogersachs's Avatar
rogersachs
Default Motor Mounts
Originally Posted by toddskill
Sound good. Where can you purchase them.
Will also change the rear mount.
Old Apr 8, 2019 | 05:54 AM
Shop rag's Avatar
Shop rag
If you weren't having lots of vibration issues or handling problems go back with stock on the rear mount. If you are feeling frisky try the Custom Cycle engineering rear mount but it's probably not needed.
Old Apr 8, 2019 | 09:22 AM
toddskill's Avatar
toddskill
Dont worry about it being a UK site. They will have it to your door in a couple days and if you use PayPal it handles the currency conversion for you. I've read post saying it takes a long time to ship if you order from the US site for some reason.
Old Apr 8, 2019 | 09:49 AM
Protocol's Avatar
Protocol
My bike follows tar snakes, freaks me out
Old Apr 8, 2019 | 10:14 AM
John CC's Avatar
John CC
I've found that pretty common on bikes with front tires that have grooves running the circumference of the tire, for example, Dunlop 401 and 402. I recall there was one called F21 or something like that which was pretty bad, too, but it doesn't seem to be a current model.
Old Apr 8, 2019 | 10:41 AM
Durham man's Avatar
Durham man
Anyone have any input on the cce mount? Kinda pricey but it is the fxr style mount.
Old Apr 9, 2019 | 12:49 AM
rogersachs's Avatar
rogersachs
Thank You,
I ordered a stock rear mount and a predator front. I hope it helps. Will post after its installed.
Roger
