vibration over 70 mph- 2013 SB
Old Apr 21, 2019 | 06:31 PM
John CC's Avatar
John CC
2 for $1.50 at Dollar General...
Old Apr 23, 2019 | 08:04 AM
crusader1xxx's Avatar
crusader1xxx
When you did the predator did you do the power train alignment procedure? If not that’s the problem, you can’t just throw it on and except miracle’s if you don’t install it correctly....plus if your running stock exhaust on a Switchback your never gonna get rid on excess vibration due to the exhaust bracket.
The single biggest thing you can do to help these bikes is that alignment procedure....
plus at at some point, there are vibrations that are just normal, it’s a 45degree motor....
Old Apr 23, 2019 | 03:05 PM
cggorman's Avatar
cggorman
1/4 turn on the neck bearing preload is a ton...unless it was way too loose to start with.
Is the vibration the same regardless of gear and engine speed?
Adding more spring preload without a matching sag measurement is vague guesswork. Once the sag and spring rate are correct, leave them alone. The rest is in the damping.
Old Apr 23, 2019 | 04:28 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Yup, you need a Lowrider! (Just so happens, mine's up for sale...)
Mark (Rooster)
Feb 16, 2016 06:14 AM
clap
Sep 6, 2015 04:55 PM
darylnj
EVO
20
Oct 21, 2014 09:15 PM
Rydertp
Feb 7, 2013 05:20 PM
lou1
Nov 16, 2010 04:10 PM
