Dying at Idle
Old Apr 28, 2019 | 10:11 PM
Dynafrom818's Avatar
Dynafrom818
Originally Posted by Coverdog
IAC motor? I just replaced mine as I was getting intermittent idle, mostly a touch high but also would drop low occasionally buy did not stall. Runs great again.
Did you try cleaning it first?
Old Apr 29, 2019 | 06:04 AM
nevil's Avatar
nevil
Originally Posted by Dynafrom818
I did spray it with throttle body cleaner. Perhaps MAF cleaner would work better?
Not really, both do the same thing. The trick is to cycle the run switch several times while doing it so the step motor moves in and out, exposing more of it.
Old Apr 29, 2019 | 06:41 AM
Coverdog's Avatar
Coverdog
Yes I did. I thought it worked too, but that didn’t last long. It was back to the same thing 15 minutes into the next ride.
Old Apr 29, 2019 | 08:54 AM
Dynafrom818
Ok. I will give that a try. Thanks!
rdnether
Electrical/Lighting/Alarm
Oct 10, 2016 04:35 PM
n7734r
Jul 2, 2016 01:19 AM
Robottom
Jun 16, 2015 08:56 PM
arejay86
Jul 13, 2013 12:19 PM
omgtkk
Aug 8, 2008 12:40 AM
