Works Performance Shocks fitment?
Old Apr 30, 2019 | 12:12 AM
Abel-Garcia_96's Avatar
Abel-Garcia_96
Stage II
Default Works Performance Shocks fitment?
Looking at buying a set of used 13.5 in. Works shocks for $425 to put on my 2004 dyna fxdl, the shocks are coming off of a 2013 dyna.
Does anyone know the years/fitment for Works?
If I remember right I thought they fit for Dynas 99 and up but I could be wrong. Having a hard time finding info on them since they went out of business.
Old Apr 30, 2019 | 01:29 AM
2004DynaRider's Avatar
2004DynaRider
.Hopefully someone else can help you there think your stock length is 12"' Not sure if that matters but been told if go over 1 inch should do both front and rear .
Old Apr 30, 2019 | 02:53 AM
Abel-Garcia_96
Stage II
Yeah I’m planning on running race techs in the front along with it.
Just not sure if the bolts/eyelets on the shock are the same from the swing arm and struts cause I know a lot of brands do 99-06 and then 06+ for dynas
Old Apr 30, 2019 | 11:14 AM
Dynaglide92's Avatar
Dynaglide92
I believe it has to do with the bushing size in the eyelets. They can be replaced to fit your application
Old Apr 30, 2019 | 12:33 PM
DynaKid94's Avatar
DynaKid94
Bushings and spacers may need adjusting but the shocks in general should fit your bike. Only potential issue I see would be exhaust/bracket clearance depending on what you're running...
Maxxsmart
May 9, 2016 11:32 AM
gant
Aug 31, 2014 06:11 PM
calabera
Dec 3, 2013 06:30 PM
Afishinado
May 5, 2012 07:01 AM
TEXAS GHOSTRIDER
Jul 15, 2007 04:07 PM
