2007 dyna wide glide
Old May 7, 2019 | 04:59 PM
Ronald Sondergaard's Avatar
Ronald Sondergaard
Default 2007 dyna wide glide
i have a 2007 dyna wide glide, and i have 43,000 miles on it....
repairs since i had it-
$400- hard drive compensator
$400- new charging system
my mechanic installed the above.
now i have a oil leak from primary side, i believe its the transmission bearing, or inner primary bearing, both range from $600- $900 repair bill..
DAMN- are these bikes that unreliable.....if i get the transmission bearing install- allmost $2000 ;total repair bills in 43000 miles..
my mechanic said the pre-2006 dynas a lot more reliable
is there a way to make this bike reliable.....or should i sell it....
Old May 7, 2019 | 06:29 PM
joe40x's Avatar
joe40x
So, you have a 12yr bike with 43k miles on it and you are surprised than it needs some repairs?
Fix it up and get another 43k miles! Get positive about it!
Get a service manual and learn how to work on it! They're fairly simple to work on.
We are all here to help you along if you get stuck!
Old May 7, 2019 | 07:20 PM
Ronald Sondergaard
i just sold my honda shadow ace duluxe 2003...it did not have much power, but it was reliable..i put 100,000 miles on it,,,,,,
3 fuels pumps..thats it...and i go tthem off ebay for $25....
Old May 7, 2019 | 10:22 PM
Dynaglide92's Avatar
Dynaglide92
Unreliable? Sometimes
expensive? Yes
simple? Yes
those repairs you paid for are not hard to do yourself. Many people (new riders) get scared of doing their own wrenching. That inner primary bearing could have been replaced when the stator was replaced. Easy 2 hour job. A manual comes in handy.
Old May 7, 2019 | 10:26 PM
Dynaglide92
Btw you mind taking a pic of where it’s leaking from?
Old May 10, 2019 | 05:22 PM
Ronald Sondergaard
u got to take primary cover off to see where its leaking...harely dealer said it was primary gasket, and shifter seal that goes into tranny...my mechanid in phoenix (iron horse corrall).....reached under the primary cover and said it was leaking from up other side of cover...said its probably shifter seal, primary seal, or main tranny seal
Old May 11, 2019 | 08:50 PM
Jonesy82's Avatar
Jonesy82
So what's the plan? Are you going to get a service manual and take care of the small issues or drop it off to a shop to have it done? We can't diagnose anything over the internet accurately, some photos would help, but a service manual and digging in would be the best bet. Gaskets are cheap, get them all, dig in, find out which one it is, then take the others back.
IMO these are simple things to take care of. I've had a VMax that I beat on that only needed valve adjustments while I had it, then the person I sold it to has had to do LOTS to it since. I've also had a Hayabusa that I did a lot of stupid repairs to along with some Jap bobbers I built. My 07 WG has been flawless, however, some things are bound to happen, as it's a piece of machinery built by humans, with parts, manufactured by humans, just like all of my prior bikes.
Good luck and keep us informed!
Old May 11, 2019 | 09:31 PM
fl_799's Avatar
fl_799
On these jobs it’s best to get educated on the procedure. I’ve done several full primary jobs like replacing inner primary bearings, compensators, welding up stator plates on the 2 piece units made in 2006 etc.
the shop manual is usually dead on. Some of the inner primary sealing bolts are not reusable. Using quality gaskets are important and torque sequence on both the inner primary and outer primary is critical. You skimp on any one area and leaks are possible. Do the job right and leaks are all but impossible.
I do this stuff myself because I know without a doubt I’ll do the job right the first time. Your bike is fine, the work is suspect.
Old May 12, 2019 | 03:32 PM
Ronald Sondergaard
i got shop manual....i have no garage....never had the primary side off or the compenstator clutch assembly....i just had a new compensator installed, makes sort of small noise going down the road at certain rpm,s...mechanic told me about it, but said its whats he put in big mortor builds.i quess i could try some of it
Old May 12, 2019 | 05:55 PM
Trench's Avatar
Trench
Sounds like you should've kept the Honda
