Sunpie Daymaker and CANBUS
Old Jun 15, 2019 | 03:37 AM
Herman1966's Avatar
Herman1966
Default Sunpie Daymaker and CANBUS
Hi Dynas,
Ive just ordered one of those Sunpie daymakers for my 2016 FXDL Lowrider which has a Canbus electrical system. I have seen the odd thread about issues with error codes and red light dash lights coming on.
I already have LED Motogadget bullet rear indicatirs and Joker Machine front indicators which both work fine upart from the dash indicator arrows flash fast.
Anyone put a Sunpie LED daymaker on a 2016 FXDL? Any issues?..apologies if this is an old topic if so please steer me to the thread.
Old Jun 15, 2019 | 06:10 AM
K9F's Avatar
K9F
There were some recent issues with the high beam being too high.
https://www.hdforums.com/forum/touri...eam-issue.html
As you've already upset the balance of your Canbus system by fitting LED indicators without load equalisers and pulled the trigger on purchase, I wouldn't worry about it too much. Just fit the Sunpie and see where you lie thereafter. LED load equalisers for your indicators are readily available and quite easy to fit. You would need two as it is a Canbus system. I bought mine from Thunderbike. If you need help fitting as I too am in Dorset I could possibly assist if the need is there?
https://shop.thunderbike.de/index.ph...t&redirected=1
Old Jun 17, 2019 | 04:53 AM
Herman1966's Avatar
Herman1966
Thanks K9F for getting back to me. I should have said I had one Thunder bike equaliser put under the seat ...I think tbat was for the rear Motogadget indicators.
As I said the dash signal arrows still blink fast which I understand is a warning signal like if a bulb has gone. Maybe I need another for the front indicators to stop this?.
It doesnt really bother me and I have been told that it is not dangerous in terms of the electrical system. If I need to get another equaliser then so be it but there not cheap!
I must admit the Sun pie high beam issue does concern me...the stock headlights are not too bad..much better than the XL 883 Iron I had before. Cant help but wonder if its worth it.!!
Old Jun 17, 2019 | 05:16 AM
Herman1966's Avatar
Herman1966
Thanks for the offer of help fitting , I will see how it goes!
Old Jun 17, 2019 | 05:29 AM
K9F's Avatar
K9F
As you’ve already ordered it you’ll have to fit it, try it and either knock it on or test out the returns policy from where you sourced it perhaps?
Without Canbus you will get away with a single load equaliser for all four indicators but with Canbus you need two. The front one is the cheaper of the two and easier to fit from an electrical perspective as it only has three wires not five. I fitted the second at the frame fork neck. Quite difficult getting access to the wiring as mine was buried inside the bars and the connectors under the fuel tank. Should in the unlikely event you have an indicator fail you wouldn’t know about it without constant physically checking. If you need a hand you know what to do!
Old Jun 26, 2019 | 04:31 PM
K9F's Avatar
K9F
Hey Rich,
Did you encounter any 'foggy conditions' on the way home from the Harley-Davidson Dealership bike meet tonight? Sunpie was experiencing misting on the inside after fitting in today's heat.
(Small World, transpires the OP is a mate of mine who didn't realise I was on the forum. We did laugh when we discussed his potential Sunpie issues on the phone earlier today and I stated there was a guy on here experiencing the same conundrum and it turned out to be him I had responded to.)
Old Jun 27, 2019 | 03:45 AM
Herman1966's Avatar
Herman1966
Default Foggy headlamp
Ha ha,
Yes great wide to Mudeford Quay...a cold beer and fresh sea air. The light is still fogging up. I have just emailed the seller, so will see what they say. Unfortunately it was twilight by the time I got home so didn't get a true idea of the light. Tonight I will check it out...
Old Jun 27, 2019 | 04:41 AM
kel03's Avatar
kel03
Off topic a bit, you two guys are funny, reminds me of my buddies wife from Greenock Scotland who has lived here in Canada for years. She picked up the phone, was on it for two hours, when she hung up, her husband said, who was it, she replied "wrong number" but the woman was from the same area back home.
Old Jun 27, 2019 | 05:35 AM
Herman1966's Avatar
Herman1966
Yeah I kinda knew it was him when he said he was from Dorset!!
Anyway..back to the Sunpie ..just taken it off and removed all 4 breathing tabs put it in the oven at 90 until it was almost too hot to handle and then put the tabs straight back on.
Hope this method works K9F !
If it doesn't I have read one guy took one tab off permanently and said he never had an issue since..
I have also heard on Utube that some of the HD daymakers fog..and they don't like replacing them !!...not surprised the amount they cost...anyway back to the garage!!
Old Jun 27, 2019 | 06:59 AM
K9F's Avatar
K9F
Only works if you plug and seal the holes whilst the lamp is still warm, as it cools it creates a vacuum. No air = No moisture. Worked for me on the first generation 8700 JW Speakers.
