Has any work been done recently? If so, look at the components involved.
Start with the obvious. Look under the rear fender to see if any wires have been damaged from hitting the wheel. When does the fuse blow? If it happens when you hit the light switch or the brakes check the switches and wiring at the controls.
Disconnect and isolate the disconnected connections in both lights. Turn them on and if the fuse doesn't rupture this will indicate the problem lies within one of the lamps. If it still blows it's the wiring.
