DIY coil relocation question..
Thanks for the follow up.
Wish you would have gotten a bit more creative with the bracket, tho. In the pic I thought it was the actual DK part. That's a testament to the quality of your work.
FWIW, I also made a DK clone but of their 636v air cleaner. Not to save money, but because I wanted a different mounting method and lighter construction. Also have a coil relocation that's a bit unique. I think my build is kinda "doing it my way" and haven't gotten any flak for it. Just give us some time.
Thats awesome. Have a post where I can see the air cleaner?
Aluminum tube from EBay cut and formed to fit a slightly modified Mikuni carb. K&N filter dyed black with Rit dye.
But now you still got that unsightly mess of wires and fuel line hanging down ruining the work you just did! Not to worry, still easy to clean up
I once looked at the horror of wires under the seat like the kid on Home Alone looked at the furnace in the basement
It ain't.Anyway, remove the seat, remove the battery, remove the three simple bolts that hold the battery box in place and all will be revealed
You can run a long narrow zip-tie around the backbone frame and to it you can throw a lasso small zip-tie around the positive cable coming from the battery to the starter, cinch it up to pull it out of the way. Bam Blamo, that one's taken care of!
You can now find the best route for your exhaust sensor to best obscure it, no need for it to ruin the work you've done either!
And what about the damn pesky fuel line that you'd swear Moco f'ed it up on purpose, well, bam blam blamo, you don't have to put up with that Bellshirt either
Then of course, there is that damn mount just sitting there looking at you like it's a third eye, like a cojoined dick growing out of the electrical caddy
Well, you don't have to put up with that either, you can clean that all up and put both your fists behind the cylinder!
Good job
The wiring reroute/cleanup is a hassle but it's also very worthwhile if you're the kind of person that notices those little things.
I did all work with a hacksaw blade (blade itself only, gloved hand) and a Dremel with a little sander bob thing whatever they are.
Make a little cap like a thumb drive cap out of the part of the mount you saw off to make the coil purge cap out of.
https://www.youtube.com/watch?v=_3rfAjpHOyI
Oh man, whyd you show me all this. Never crossed my mind. Now it looks like I have more work to do haha
Cleaned it up so much! Looks good!
