Neutral Switch Gone Bad???
Old Aug 4, 2019 | 10:59 AM
bobnehoc's Avatar
bobnehoc
Default Neutral Switch Gone Bad???
So I jumped on the scoot this morning and when I went to fire her up I noticed the Neutral Light did not light up. The bike is an 07 Low Rider and no recent work performed on her. Al the other lights worked, oil,h-beam, directionals. Put about 50 or so miles on her and the light never came on. When I got back home I began to diagnose the problem. Pulled out the manual and checked the schematics. The neutral switch has two wires, tan and black. tan runs to the circuit board, black is ground. Broke out the VOM and I have continuity on the tan wire from the circuit board to the neutral switch. I put the leads across the terminals on the switch and I had continuity. Is that a good way to test the switch? It is a $15 part on Ronnies, but the circuit board is no longer available. I don't mind swapping the switch out but If it turns out to be the led on the circuit board, does anyone know of a place that repairs circuit boards?
petewood70
EVO
15
Jun 19, 2020 05:08 PM
BACADon
Oct 30, 2015 04:47 PM
falconbrother
EVO
Oct 3, 2014 03:26 AM
Mark103
Apr 22, 2010 12:45 PM
oldhippie
Nov 4, 2009 08:24 PM
