Engine mounts, yes again I hear you say.
Old Aug 30, 2019 | 03:54 PM
r46jack's Avatar
r46jack
Looks an interesting read, thank you. just another thing to add, the vibrations, my rear pegs fold themselves down after only 15/20 miles.
Old Aug 30, 2019 | 08:21 PM
cggorman's Avatar
cggorman
My pegs are very stiff so it would take a literal paint shaker to move them. Regardless, Make sure you isolate drivetrain from chassis as best you can when diagnosing vibes at speed. Slightly above the vibration speed(s), declutch and let the engine idle down while the bike coasts thru the vibration speed range. If the vibration still occurs, it's very likely NOT the mounts.
Some exhausts, when loose or misaligned, have been known to create some pretty bad vibes. Tire/wheel balance, of course, is always possible. Engine tune can change vibrations, too. Also, anything else loose can contribute.
Old Aug 31, 2019 | 02:44 AM
r46jack's Avatar
r46jack
Thanks, yes I've done the above several times at different speeds, different gear, wind her up to 4000rpm, pull clutch in to idle, coast beautifully, it's not speed related.
89FLHTC
EVO
29
Apr 29, 2016 05:37 PM
newdyna
Jan 20, 2016 10:22 AM
ditchbanger
Jul 12, 2015 08:57 PM
SgtDuckyBoy
Exhaust System Topics
Mar 2, 2012 12:19 AM
Gary7
Apr 16, 2009 05:09 PM
