Help 07 fxdb problem
Old Oct 8, 2019 | 12:17 PM
Srh Goon's Avatar
Srh Goon
1st Gear
Default Help 07 fxdb problem
Hey guys got my dyna went for a ride and started to loose power stopped and would not turn back on acted like it wasn’t charging so took it home and uncle jumped it with a running truck so I replaced tssm to tsm and a new ecm and the hole charging system with a new battery all married together... here’s the thing it’s a 96 conversion to a 103 and I got it running and I put it in gear and it dies right away or in neutral and I rev it it dies what to do next?
Installed
Ecm new
Tsm from running 03 low rider
New stator, rotor, regulator, battery
Runs ok on idle t
But once u put it in gear or rev it it dies
Everything is married but cons
Not tuned
96 to a 103 build
Suggestions?
Old Oct 9, 2019 | 12:11 PM
nevil's Avatar
nevil
Wow. You spent a lot of money so far. Hope the parts you replaced were diagnosed to be bad.
First thing I would do is check for codes.
Old Oct 11, 2019 | 08:21 AM
Cubby89's Avatar
Cubby89
Bingo
taylo413
Jun 12, 2019 10:52 PM
cabowabodude
Jun 17, 2012 09:43 AM
desolationj
Jun 8, 2012 05:33 AM
FXDL68
Sep 20, 2007 03:19 PM
hogfanatic
Feb 24, 2007 05:22 PM
