Oil drip continues
Old Nov 5, 2019 | 07:30 AM
  #31
John CC's Avatar
John CC
Originally Posted by jandrso
The problem is the bike won't start at all right now. even thought there is juice in the battery (10.6v) not even an idiot light will come on.
Well, 10.5 volts is 0% charge. You have to get to 11.3v to reach 10%, so I wouldn't say "there is juice in the battery".
First thing to do is charge the battery (12.6 volts is 100%) and have it tested.
Old Nov 6, 2019 | 09:31 AM
  #32
NORTY FLATZ's Avatar
NORTY FLATZ
Actually, 13.2V is "fully charged." (Each cell is 2.2V when fully charged.)
This is for a typical AGM or lead acid battery of cells.
But back to the OP.
10.6V is deader than a door nail.
3 years is about right for a Yuasa battery on average. (Yeah, yeah, I know. Some get 7 years outa their batteries. Some get 8 months. )
Old Nov 6, 2019 | 10:36 AM
  #33
zebraranger's Avatar
zebraranger
The battery should be load tested (free at auto parts stores). Even if you bench charge it to just over 13 volts, it still could be bad and drop instantly under load. I've had this happen twice in recent years, not on the Dyna, but on one of my other bikes (Moto Guzzi), and I always use battery maintainers.
Old Nov 6, 2019 | 02:31 PM
  #34
John CC's Avatar
John CC
Flooded cell lead acid chemistry was good for 2.1 (actually 2.12) volts per cell, or 12.6 - 12.7 volts for a conventional 12 volt battery. You can charge them to a little more than that, but it's what called "surface charge" and as soon as you put a load on the battery it disappears. AGM batteries are a little higher and 2.2 volts per cell or 13.2 volts for a 6 cell, 12 volt battery.
Old Nov 6, 2019 | 06:29 PM
  #35
John CC's Avatar
John CC
Just reviewed all the battery related posts. You've had two consecutive rides that resulted in two dead batteries. I think the inescapable conclusion is that your charging system is shot, and it's pretty likely there's nothing wrong with (either) battery.
Old Nov 6, 2019 | 06:34 PM
  #36
John CC's Avatar
John CC
Originally Posted by zebraranger
I've had this happen twice in recent years, ... and I always use battery maintainers.
This is why I no longer keep any batteries on maintainers continuously. YMMV...
Torpedo1
Jan 29, 2019 10:30 PM
ShotgunYoungOhio
Jul 13, 2015 06:50 AM
bigirn
Exhaust System Topics
13
Apr 7, 2013 10:09 AM
Pagman
Jun 21, 2012 07:25 PM
dynacruiser
Mar 19, 2011 07:51 PM
