Battery is over charging.
Old Dec 22, 2019 | 09:59 PM
David Hansen's Avatar
David Hansen
6th Gear
Default Battery is over charging.
Battery is over charging. It has burned up two batteries. It is also blowing out other electrical components. The speedometer is dead. The headlight is out no turn signals and maybe the fuel pump. The bike died and there was battery acid all over. It did this twice.
Old Dec 22, 2019 | 11:21 PM
hvacgaspiping's Avatar
hvacgaspiping
Bad voltage regulator........
Old Dec 23, 2019 | 06:34 AM
CoolBreeze3646's Avatar
CoolBreeze3646
So what is your question?
Year and model of your bike?
You knew it was over charging and burnt up a battery yet you put another one in there without investigating why the first one went bad.
Probably need to take it to someone who knows what they are doing.
Good luck.
Old Dec 23, 2019 | 09:15 AM
David Hansen
6th Gear
Good luck.
didn't know it was over charging on the first one.
If I take it to someone else I will never learn 😉 I'm here for help not douchebag comments
Old Dec 23, 2019 | 09:17 AM
David Hansen
6th Gear
could that have fried the fuel pump?
Old Dec 23, 2019 | 09:21 AM
O-Town D's Avatar
O-Town D
The extreme voltage could have blown several fuses......
Old Dec 23, 2019 | 09:22 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Everything is designed to run at 14.4 volts with some overhead. If you boiled a battery then yes you could well damage some other parts on your bike.
Old Dec 23, 2019 | 09:29 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Your first post did not make any mention of you not knowing the problem existed on the first one, this is exactly what you posted:
If you want help from people, explain the issue, give the model and year, and above all, don`t be a Dick.
Old Dec 23, 2019 | 09:35 AM
David Hansen
6th Gear
I checked the fuses and I don't have any blown.
Old Dec 23, 2019 | 09:42 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted
