Battery is over charging.
Old Dec 23, 2019 | 04:17 PM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by David Hansen
could that have fried the fuel pump?
Sure, without the voltage being regulated from the alternator delivering its maximum voltage, not only could the fuel pump be fried, but other electrical components as well (headlights, turn signals, radio, speedometer, etc.). These items aren`t designed to take much more than 14 volts applied steadily, and the higher the voltage the shorter time it would take to cause them to fail. The stator of the alternator in a modern HD motorcycle can produce as much as 54 volts at 3000 rpm, so it`s obvious why a means to regulate the output voltage is needed.....
Old Dec 30, 2019 | 06:43 PM
David Hansen's Avatar
David Hansen
6th Gear
Where is the best place to buy the parts I need?
Road Gliderman
Electrical/Lighting/Alarm
17
Feb 24, 2019 12:34 AM
JOW_103
Dec 29, 2014 03:49 PM
Booey424
Sep 18, 2011 11:45 AM
84sugar
Sep 10, 2009 04:08 PM
sonar_chris
Jan 10, 2009 10:42 AM
