fill fork tubes from bottom 2011 superglide 49mm
Old Feb 7, 2020 | 08:50 PM
Ghost_13's Avatar
Ghost_13
Originally Posted by millsym2k
yes fully assembled ..ive not got round to doing job yet...yes the plug in bottom of forks that holds shocker internals under axle is where im was going to try filling ....
Do that - and you'll **** it up
And be lucky to re-tighten that retaining bolt back up - likely the internals will spin
But hey - it your scoot
Ghost
Old Feb 7, 2020 | 10:31 PM
crusader1xxx's Avatar
crusader1xxx
...well....don’t ask for advice then ignore it...almost everyone one here has said to take them apart...so why wouldn’t you?
like I said, there is a right way to do things and the wrong way...sometimes you can get away with it on non critical things..suspension is not one of them....
don’t be that “hack” mechanic that screws up a part that costs $$$ to save a dime. Or costs you your or someone else’s life
Old Feb 7, 2020 | 10:53 PM
multihdrdr's Avatar
multihdrdr
Slow down ... Read or Re-read post#19
Old Mar 20, 2020 | 03:24 PM
millsym2k's Avatar
millsym2k
i found when i came to fill new fork tubes that the old ones were bent so that is why i couldnt press bungs in fork top ...after changing lowers i was able to press new bungs back together ..so used old way of measuring oil as you suggested ..it s always best that way was just fooled by almost non existent curve in old tubes stopping spring from compressing ..
Old Mar 20, 2020 | 03:29 PM
millsym2k's Avatar
millsym2k
this bend in fork was also reason my spacer tube stuck out four inches after i removed fork top bung... beware when unscrewing a bent fork tube the spring is more compressed and stuck up the stanchion heavily loading the fork top bung much more than is normal ...always a tentative moment but much more so on bent forks
Old Mar 20, 2020 | 08:28 PM
Max Headflow's Avatar
Max Headflow
So you got marks in the ceiling now?
Spazz
2014-2024 Touring Models
53
Jan 8, 2018 11:49 PM
woody1978
Jul 10, 2017 12:07 PM
hscic
Jun 13, 2016 07:03 PM
Barrier
Oct 1, 2014 05:14 PM
Thornhammer
Jul 27, 2009 12:45 PM
