Dead Wide Glide !
Old Jul 20, 2007 | 05:51 PM
Oldtimer of NM's Avatar
Oldtimer of NM
Default RE: Dead Wide Glide !
Sounds like a loose battery cable to me.
Old Jul 20, 2007 | 07:50 PM
Sabaka454's Avatar
Sabaka454
Definitely check your B+ and B- connections and the negative post under the seat as suggested. Also check the connections directly at the starter and make sure it's bolted in tight.
Old Jul 21, 2007 | 02:22 AM
sgt joseph's Avatar
sgt joseph
Run it in a dark garage......headlight disconnected, seat removed etc........If its arcing off you should see the sparks or arcing !......Of course make DAMN sure the garage door ain't completely closed as not to
get carbon monoxide poisoning or worse !
Old Jul 21, 2007 | 07:39 PM
Jag120's Avatar
Jag120
OK, the prize goes to all of you that mentioned a loose grounding wire. The dealer picked it up Thursday and late Friday they called to profusely apologize that it was a loose grounding wire to the frame. They never tightened it when they disconnected it installing the Fuel Pak.
Thanks, guys. You all pretty much nailed it on the head. I had wanted to pull the seat off when I got stuck, but when the dealer mounted the rack on the rear fender, they replaced the slotted head screw with a torx screw and I didn't have a torx wrench on the road.
Ya gotta love HD forum.
Old Jul 22, 2007 | 11:45 AM
mtnlvr's Avatar
mtnlvr
Glad to hear it was nothing serious...too bad you had too be without your ride though. And I'm sure it sucks to see 'er hangin' on the back of a tow truck.
Old Jul 22, 2007 | 02:28 PM
Airborne350G's Avatar
Airborne350G
Sweet, glad to hear that t was something easy. Especially when it is the same color as mine.
JT-FXDL
Sep 7, 2012 10:53 PM
Sujada
Aug 16, 2012 09:58 PM
2kanzam
Sep 2, 2010 03:42 PM
TurkeyRun
Jun 22, 2009 12:01 PM
ape.hanger883
Aug 21, 2008 08:49 PM
