Bad gas, won't start
Old Mar 7, 2020 | 11:44 PM
GeorgeG's Avatar
GeorgeG
I was amazed at how corroded and rusty all the steel parts were inside the tank, even considering how long the bike sat. I realize that the bike needs to be run more but does going to the trouble of buying gas with no ethanol in it reduce this issue?
George
Old Mar 8, 2020 | 07:49 AM
John CC's Avatar
John CC
Yes. Ethanol is an oxygenator. Rust is Iron oxide. Plus, the ethanol absorbs water from the air. If the bike has to sit, keep the tank full to minimize the air, and use ethanol free gas or treat the gas with a stabilizer.
Old Mar 9, 2020 | 10:15 AM
GeorgeG's Avatar
GeorgeG
Thanks,
George
Old Mar 10, 2020 | 07:28 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Worst case is putting some grinding media inside the tank, cover up all holes as best you can, then put the whole tank in a paint shaker. Fill the tank about 15-20% full of media. Let "shake" for an hour, then check the insides for progress. Like I said, this is a last ditch effort. Good luck getting all the media out. It needs to be dry for the media to expel.
Old Mar 10, 2020 | 08:06 PM
John CC's Avatar
John CC
Use drywall screws. Count them. Much easier to get them all out. shaking is not necessary. You can roll it around.
Old Mar 11, 2020 | 04:54 PM
GeorgeG's Avatar
GeorgeG
Despite how rusty all the steel innards were and how much rust debri was in the bottom of the tank, the tank itself was not that bad. Obviously the tank inside is coated with something because it is steel and barely rusty. I decided not to disturb that coating and assume that if i scrubbed the loose rust in the very bottom where everything collected and vacuumed and cleaned out the tank that we should be good. I decided to use gasoline and rags to wipe everything out and rinse the tank. That way, no flash rust from water based stuff and I didn't strip the inside coating with a solvent. Tomorrow all my new parts arrive so well see how the minimalists approach holds up. I have to replace everything inside the tank.
George
Old Mar 11, 2020 | 08:47 PM
John CC's Avatar
John CC
So, if it wasn't the tank, what was rusting?
Old Mar 11, 2020 | 09:44 PM
GeorgeG's Avatar
GeorgeG
The underside of the top plate was shedding sheets of rust. All the steel brackets and clips of the fuel pump and float assemblies.
George
Old Mar 28, 2020 | 10:53 PM
GeorgeG's Avatar
GeorgeG
So I needed to clean the tank, replace the fuel pump, filter, regulator, tank quick connect/hose, and fuel level float. I did not touch the external fuel hose or the injectors. I put in fresh gas of course. It's running great. I need to change the spark plugs tomorrow and I should be done.
George
George Tirebiter
Jul 8, 2016 12:32 PM
Bravzfan
Jan 20, 2015 09:44 PM
KUJOE
Oct 13, 2012 03:24 PM
pmedic433
Sep 13, 2011 05:36 PM
518Train
Exhaust System Topics
Sep 17, 2008 10:02 PM
