2014 Street Bob clutch adjustment?
Old Feb 23, 2020 | 01:06 PM
Brandon Dickel's Avatar
Brandon Dickel
6th Gear
Default 2014 Street Bob clutch adjustment?
Hello everyone,
I recently bought a 14 street bob and love it. I’m having troubles finding neutral when the engine is running at a stop. I’ve been adjusting my clutch pack and lever to try to fix it, but can’t seem to. I feel like I can only fully disengage the clutch if the lever is way too stiff. I also have some forward pull still if the clutch is pulled all the way in. I currently backed out the set screw on the under the derby cover 1/2 turn. Any help? Should I back out more, or less? I’ve read articles on this but can’t seem to figure it out.
Old Feb 23, 2020 | 05:41 PM
Rapidfire1's Avatar
Rapidfire1
Anytime on a bike I've not been able to adjust the clutch I've always back off all adjustments and started over from scratch following the manual to a T. Even on a bike I've done it dozens of times on. When I do my street bob I adjust the clutch pack and then the cable even if it's just to take a bit of slack out.
Old Feb 23, 2020 | 07:16 PM
TexasScooterTrash's Avatar
TexasScooterTrash
2014 bikes have self adjusting primary chain tensioners. What they actually do is over tighten the chain, which makes it almost impossible to find neutral. Replaced mine with a Hayden Tensioner some 65,000 miles ago. I can click it into neutral as I'm rolling to a stop every time.
Old Feb 23, 2020 | 08:25 PM
Ghost_13's Avatar
Ghost_13
^ What he said - could also be the brand of primary oil you're using - as well as the level the primary filled to
Found some better than others at allowing the clutch to engage - thus making finding neutral easier
fwiw
eta - and no I don't want to get into an oil debate / how much to use - experiment
Ghost
Old Feb 25, 2020 | 06:16 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
When I know I am going to do a clutch adjustment it's done before any engine/ primary heat gets in the cases. I've found the videos on this procedure vary just as much as some inputs do from websites. If you don't have an owners manual (O/M). I believe you can go on HD website and down load one for your make and model, lot's of info in the O/M.
svt_ct
Oct 26, 2011 08:40 AM
June Bug
May 21, 2011 03:44 PM
June Bug
Aug 30, 2010 12:38 AM
jimd4au
Aug 5, 2007 02:14 PM
MasterRye
Aug 9, 2006 01:56 AM
