2000 Dyna Wide Glide
Old Jun 24, 2020 | 05:22 PM
Longthorne3's Avatar
Longthorne3
Stage I
Default 2000 Dyna Wide Glide
Just bought a 2000 Dyna Wide Glide, rose it home, now it won’t start, I’ve change the ignition coil, spark plugs, plug wires, battery, relay, and circuit breaker, Cleaned the carb and rebuilt it, still seems to not be getting a spark.
Old Jun 24, 2020 | 10:03 PM
WS6 Formula's Avatar
WS6 Formula
It might be the Crank Position Sensor:
Crank Position Sensor Failure on '04 Dyna
https://www.hdforums.com/forum/dyna-...n-04-dyna.html
Dyna FXDX 2000 ERROR Code 41
https://www.hdforums.com/forum/dyna-...code-41-a.html
HARLEY-DAVIDSON® PARTS FINDER
https://shop.suburbanharley.com/oem-..._SENSORS_%26/y
Old Jun 25, 2020 | 12:13 AM
Tommy B's Avatar
Tommy B
I have a '00 WG also.Did the bike throw a code? When the ignition switch is turned on the engine light comes on for 4 seconds then turns off. If it stays off you're good, no codes. If it comes back on for 8 seconds then goes off, there's a stored code. If the light comes back on and stays on, there's a current code. There's a procedure in the book for reading the codes using a jumper and the engine light, you don't need the Harley scan tool. That's how I diagnosed my bad CKP, which caused very similar symptoms to yours.
run1fsr
Motorcycles For Sale
Apr 27, 2015 05:10 PM
dusturb
Sep 26, 2010 06:15 PM
dennyandnancy
Feb 24, 2008 01:45 PM
FatboyRules
Jul 23, 2007 10:42 AM
gunz
Mar 15, 2006 02:54 AM
