My bob is still stuttering
Old Jul 23, 2020 | 03:41 PM
nevil's Avatar
nevil
HD manual recommends using propane torch (unlit). So you can use that. People use carb cleaner, WD40, brake cleaner and all kinds of stuff to detect leaks. I just gave you the safest chemicals. All you're doing is seeing if the leak will suck the spray inside. If you want to find something else, feel free.
What you need to do, besides getting a service manual, is to spend some time and do some research online. Plenty of posts, forums and YouTube to look at.
Old Jul 23, 2020 | 03:43 PM
falikmike's Avatar
falikmike
another suggestion for stuttering was speed sensor abouve the gears
Old Jul 23, 2020 | 04:04 PM
falikmike's Avatar
falikmike
what if air filter is dirty? Like here
the guy says it fixed it
can you use alcohol to clean it or you need a carb spray cleaner?
Old Jul 23, 2020 | 08:20 PM
Suede Blue Man's Avatar
Suede Blue Man
I had a some Stroh rum in Germany once, that **** will make you stutter, it'll give you two stutters!
Old Jul 23, 2020 | 08:40 PM
nevil's Avatar
nevil
That is not an air filter, that's the IAC. The air filter is not even installed in the video.
But, I think that copious amounts of alcohol would be in order. So, props to Suede Blue Man.
Old Jul 24, 2020 | 04:56 AM
falikmike's Avatar
falikmike
so i checked IAC around the flap, it was dirty but I clened it with paper towel...so nothing permanent sticking there....
also checked speed seonsor if there are any filings....nothing.....
removed power commander 5 and run it without, same stuttering...nothing changed....so PC5 is not the culprit
I guess it could be intake manifold leaks?????
I also cleaned air filter.....
Old Jul 24, 2020 | 04:57 AM
falikmike's Avatar
falikmike
i have soldering think with porpane gas inside....could that help? without turning the flame on?
Old Jul 24, 2020 | 08:28 AM
nevil's Avatar
nevil
Correct.
The IAC is not the flap. It is inside the throttle body opening near the top. It only affects the idle, but it can't hurt to clean it.
Old Jul 24, 2020 | 08:53 AM
falikmike's Avatar
falikmike
i cleaned it with alcohol.....so idle is now ok I think but low rpm is still bad
in harley service they told me they use break cleaner to clean the sensor....and other say that is too harsh....
i need to check valva intake leaks.....i have small lighter gas cans that I use to fill cigarette lighters....will that help?
Old Jul 24, 2020 | 03:13 PM
Mid-Night-Rider's Avatar
Mid-Night-Rider
I had a stuttering issue years ago and I hosed off the IAC and everything else in the TB with WD40 and that solved the issue. Made the exhaust smell like burning WD40 for a few minutes. It would also be worth it to remove the CPS (crank position sensor) and wipe that off. Not likely the culprit, but it's an easy 5 minute job.
There's also a known issue with the in tank fuel line rubbing against the inside of the tank wearing small hole(s) in the line causing low fuel pressure. I had this issue too. But I thought by 2014, they (HD) fixed that, but maybe not. Only way to find out is to test the fuel pressure or remove the fuel pump assembly and inspect the lines. Look for flat spots on the corrugated plastic line that goes from the pump to the regulator.
